I've been learning VHDL this semester and am trying to build a program that can take two input signals and cross correlate them. I've tried to implement a brute force summation algorithm, but it seems like the compiler just ignores most of what I tried to do. I think this means I'm writing un-synthesizable code, but I haven't yet figured out how to know if what I write can be created in hardware or not. Here's one of my tries so far. Ultimately I'd like to make the inputs vectors of unsigned or standard logic, but for now I just want it to work with anything.
PACKAGE dataTypes IS
TYPE inputVector IS ARRAY (NATURAL RANGE <>) OF INTEGER;
TYPE outputVector IS ARRAY (NATURAL RANGE <>) OF INTEGER;
END PACKAGE dataTypes;
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
USE work.dataTypes.all;
ENTITY xcorr is
GENERIC
Nrcv: NATURAL := 16;
Nknwn: NATURAL := 4
PORT
rcvSig: IN inputVector(1 TO Nrcv);
knwnSig: IN inputVector(1 TO Nknwn);
clk: IN STD_LOGIC;
corrSig: OUT outputVector(1 TO (Nrcv+Nknwn-1))
END ENTITY;
ARCHITECTURE circuit OF xcorr IS
CONSTANT zeroKnwnSig: inputVector(1 TO Nknwn) := (OTHERS => 0);
CONSTANT padRcvSig: inputVector(1 TO (Nrcv + 2*Nknwn)) := (zeroKnwnSig & rcvSig & zeroKnwnSig);
BEGIN
compute_output: PROCESS (clk)
VARIABLE tempCorrSig: outputVector(1 TO (Nrcv+Nknwn-1)) := (OTHERS => 0);
VARIABLE sum: INTEGER;
BEGIN
IF clk'EVENT AND clk = '1' THEN
FOR i IN 1 TO Nrcv LOOP
sum := 0;
FOR j IN 1 TO Nknwn LOOP
sum := sum + knwnSig(j) * padRcvSig(i+j);
END LOOP;
tempCorrSig(i) := sum;
END LOOP;
--ELSE
--NULL;
END IF;
corrSig <= tempCorrSig;
END PROCESS;
END ARCHITECTURE;
You need to draw yourself a timing diagram. What you have written is analogous to C-code where you have all the samples in a vector.
In hardware, you're more likely to have two new samples valid on every clock. To start with, you would zero out an accumulator, and on every subsequent clock, multiply the two new samples together and then add the product to a running sum. That running sum would be accumulated for a user defined period (your vector length), and then that "correlation" estimate would be output. The accumulator would be zeroed, and the process repeated. Your approach assumes that the timing of the two signals is known and identical, i.e., that both signals show up at the same time. If there is uncertainty in the relative timing of signals, then you will need to perform this calculation at multiple delays, or "lags". If you calculate the cross-correlation at multiple lags, you can Fourier transform the lags into a cross-power spectrum. The phase-slope of that spectrum is the relative delay of the correlated signal in the two inputs. Cheers, Dave- Mark as New
Dave,
Thank you for taking a few minutes to explain how to me some of the "big picture" I'm missing here. It took me some time to finally get all of my assignments to have the correct sizes and types, but:LIBRARY ieee;USE ieee.std_logic_1164.all;
USE ieee.math_real.all;
ENTITY xcorr is
GENERIC
-- length of the known signal
lenKnown: NATURAL := 4;
-- bit depth of a sample
bitDepth: NATURAL := 12
PORT
rcvPt: IN STD_LOGIC_VECTOR(bitDepth-1 DOWNTO 0);
clk: IN STD_LOGIC;
corrPt: OUT STD_LOGIC_VECTOR(NATURAL(CEIL(LOG2(REAL(lenKnown) * (2.0**(REAL(bitDepth)**2.0))-1.0))) DOWNTO 0)
END ENTITY;
TYPE sampData IS ARRAY (NATURAL RANGE <>) OF SIGNED(bitDepth-1 DOWNTO 0);
TYPE multData IS ARRAY (NATURAL RANGE <>) OF SIGNED((bitDepth**2)-1 DOWNTO 0);
CONSTANT sigKnown: sampData(0 TO lenKnown-1) := ((0 => '1', OTHERS => '0'),(0 => '1', OTHERS => '0'),(0 => '1', OTHERS => '0'),(0 => '1', OTHERS => '0'));
BEGIN
VARIABLE sigRec: sampData(0 TO lenKnown-1) := (OTHERS => (OTHERS => '0'));
VARIABLE sigMult: multData(0 TO lenKnown-1) := (OTHERS => (OTHERS => '0'));
VARIABLE sum: SIGNED(NATURAL(CEIL(LOG2(REAL(lenKnown) * (2.0**(REAL(bitDepth)**2.0))-1.0))) DOWNTO 0);
BEGIN
sum := (OTHERS => '0');
FOR i IN lenKnown-1 DOWNTO 1 LOOP
sigRec(i) := sigRec(i-1);
END LOOP;
sigRec(0) := SIGNED(rcvPt);
FOR i IN 0 TO lenKnown-1 LOOP
sigMult(i) := RESIZE((sigRec(i) * sigKnown(i)), (bitDepth**2));
sum := sum + sigMult(i);
END LOOP;
ELSE
NULL;
END IF;
corrPt <= STD_LOGIC_VECTOR(sum);
END PROCESS;
END ARCHITECTURE;
and in the tiny bit of testing I've done so far it works and it works fast (~8ns delay)! I guess this approach seems more like a detector to me than the mathematical idea of a cross correlation, but I think I'm starting to think in discrete time.
Here's some more info to get you started ...
http://www.ovro.caltech.edu/~dwh/wbsddc/correlator_efficiency.pdf including how this relates to a discrete correlation. Cheers, Dave- Mark as New
Wow, what a small world. I didn't realize until I saw your name on the pdf that I've read through your thesis several times. I used to do acoustics research for the US Navy and they basically handed me a copy of your thesis to read on the first day. Thank you for all the help then too!
Pat- Mark as New
Hi Pat,
--- Quote Start --- Wow, what a small world. I didn't realize until I saw your name on the pdf that I've read through your thesis several times. I used to do acoustics research for the US Navy and they basically handed me a copy of your thesis to read on the first day. Thank you for all the help then too! --- Quote End --- Ha! That is classic. I'm glad to have been able to help you :) Here's what I'm working on now: http://www.ovro.caltech.edu/~dwh/wbsddc/altera_fpgas_in_radio_astronomy.pdf At the time I finished my thesis, there wasn't exactly a lot going on in the world of SAS. Things have changed now though, a lot of well-known names in the field have just spun-off this company: http://www.krakensonar.com/index.php/en/technology/synthetic-aperture-sonar Cheers, Dave
