17263 Discussions
Help with latches but can't figure out why after several checks
Hi all can someone figure out why this code gives the following error in Quartus II (vs 13):
It's about finite state machines with keys, ledG, ledR and 5 states (opened, closed, locked, unlocked, error):
Here comes the code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity VHDL_uppgift_4c is
port (
clk : in std_logic; -- sync clock signal
reset_n: in std_logic; -- async reset signal
key_0 : in std_logic; -- door open input button
key_1 : in std_logic; -- door closing button
key_2 : in std_logic; -- button pressed and door locks
key_3 : in std_logic; -- button pressed and lock opens
LED_out: out std_logic_vector(1 downto 0);
LED_R: out std_logic_vector(2 downto 0)
end VHDL_uppgift_4c;
architecture final_syn of VHDL_uppgift_4c is
type state_type is (closed, opened, locked, unlocked, error); -- register to hold current state
signal current_state, next_state : state_type; -- defination of register of inner states
-- state register
begin
process (clk, reset_n)
begin
if reset_n = '1' then -- async reset of machine
current_state <= closed; -- default state after reset
elsif (rising_edge(clk))then -- sync part of machine
current_state <= next_state;
end if;
end process;
process(current_state, key_0, key_1, key_2, key_3)
begin
case current_state is
when closed =>
if key_0 = '1'then
next_state <= opened;
LED_out <= "00";
else
next_state <= closed;
LED_out <= "01";
end if;
when opened =>
if key_1 = '1' then
next_state <= locked;
LED_out <= "10";
else
LED_out <= "11";
end if;
when locked =>
if key_2 = '1' then
next_state <= unlocked;
LED_R <= "000";
else
LED_R <= "001";
end if;
when unlocked =>
if key_3 = '1' then
LED_R <= "010";
else
next_state <= error;
LED_R <= "110";
end if;
when error =>
if key_3 = '1' and key_0 = '1' then
LED_R <= "101";
else
LED_R <= "111";
end if;
--when others =>
--next_state <= error;
end case;
end process;
end final_syn;
Error message reads:
Warning (10631): inferring latch(es) for signal or variable "LED_out", which holds its previous value in one or more paths through the process
Warning (10631): inferring latch(es) for signal or variable "LED_R", which holds its previous value in one or more paths through the process
____---------------------------
Thanks for helping out
There are cases in your code where LED_out retains the previous value.
To avoid latches you need to always give LED_out a value that depends only on the process inputs (state, key*).
If you need LED_out to have memory, make it a flip-flop.
Same for LED_R
--- Quote Start ---
Same for LED_R
--- Quote End ---
Thanks for your quick reply rbugalho,
I am a beginner to vhdl, please an example will help me understand what you mean better.
Just one will do, thanks
In an async process, all signs must be assigned in ALL branches. In your code, LED_out is only assigned in the closed and opened states - it must also be assigned in all of the other states.
The way to avoid this is assign all signals in an asynchronous process a default value before the case statement. This way, if it is not assigned a specific value in a branch, it will take the default assignment.
process(state) begin output <= '0'; --default assignment case state is when state1 => --do something --no assignment to output means it will be '0'; when state2 => output <= '1'; --overrides default assignment when state3 => --no output assignment, output is '0' again end case; end process;
This way latches are avoided.
--- Quote Start ---
--- Quote End ---
Hi Tricky, thanks for the tips it worked. Wow!! you guys are good, but i got another hitch can figure out what happened:
Error message when i tried the second time to compile it:
Error (125048): Error reading Quartus II Settings File C:/altera_trn/VHDL_uppgift_4e/VHDL_uppgift_4e.qsf, line 41
Info (125063): set_global_assignment -name EDA_TEST_BENCH_MODULE_NAME "VHDL_uppgift_4e_vhd_tst " -section_id "VHDL_uppgift_4e_vhd_tst "
Error (125022): Section identifier missing or not required
Info (125063): set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst -section_id eda_simulation"
Info (125063): set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst " -section_id eda_simulation
Info (125063): set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst -section_id eda_simulation"
Info (125063): set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst " -section_id eda_simulation
Error (125080): Can't open project -- Quartus II Settings File contains one or more errors
Error: Quartus II 64-Bit Hierarchy Elaboration was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 381 megabytes
Error: Processing ended: Thu Dec 12 12:47:21 2013
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:00
Is there a file i might not have added to settings > files > at the moment i just have the VHDL in place
