17241 Discussions
Hi, While trying to compile the project in Altera_quartus linux environment quartus_map fails abruptly with the following message. > Running quartus_map input in flex scanner failed. What is the reason behind this failure ?
AD0001
  Running quartus_map
mv: cannot stat '/home/nis/abd/svn/hw/trunk/pd/fpgas/cfpga/par/cfpga.map.rpt': No such file or directory
ERROR: quartus_map exited with Non-Zero Error code
     See /home/nis/abd/svn/hw/trunk/pd/fpgas/cfpga/par/cfpga.map.err for details
============   ERRORS     ==============
See /home/nis/abd/svn/hw/trunk/pd/fpgas/cfpga/par/cfpga.map.log for details
SyafieqS
Hi Aneesh,
May I know following info for better investigation
  1. OS type and version
  2. Your machine spec
  3. Quartus type and version
Can you navigate to this path in your directory /home/nis/abd/svn/hw/trunk/pd/fpgas/cfpga/par/cfpga.map.log and share the log file here and cfpga.map.err as well
AD0001
Please find the system details below.
16.04.1-Ubuntu x86_64bit
         product: Intel(R) Xeon(R) CPU E5-2643 v4 @ 3.40GHz
         vendor: Intel Corp.
         physical id: 1
         bus info: cpu@0
         capacity: 3700MHz
         width: 64 bits
Quartus 16.1
Log file is attached.
cfpga.map.err file is empty.
Aneesh
