I have a problem, a style probem. In my design, some blocks might switch from a more performing and more resource consumming architecture to a less performing and less occupying one. Which architecture will win is still to be decided. I wish I could switch between those architectures by changing the value of a constant in a global package and having it work in the configuration section of the top level architecture. Something like: configuration CFG_TOP of TOP_FILE is for schematic for I_1,I_2: code_1 use configuration slow_cfg when global_switch='1' else use configuration fast_cfg; end for; end for; end CFG_TOP; Should this global package constant work, I could switch several blocks from architecture to architecture at the same time, having not to worry for forgetting a code. Can anybody help me to solve this problem? Thank you, Simona.Link Copied
Topic Options
