17267 Diskussionen
How can I make the compilation to achieve MEMORY using RAM but not LEs?
Geehrter Beitragender II
1.892Aufrufe
Hello everyone!
I write the program to achieve RAM like this:
TYPE MEMORY IS ARRAY (0 TO 127) OF std_logic_vector(15 DOWNTO 0);
SIGNAL RAM_DATA : MEMORY;
When the Quartus II 6.1 to compilate it,Quartus II used the LEs to achieve it ! My question is how I can let Quartus II achieve it by the intenal memory of cyclone II ?
Thanks!
10 Antworten
996Aufrufe
by the way, I turned "Assignments->settings->Analysis & Synthesis Settings->more settings->auto ram replacement" option on,but it seems no use~
996Aufrufe
Also, I don't want to achieve it by creating new megafunction!
996Aufrufe
Lots of info on this subject here
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
Quartus will only infer a RAM if it is actually implementable in internal RAM. i.e. it must be synchonous and adhere to various rules.
Check out the code samples in the above doc
996Aufrufe
Thank you! I will try it.
996Aufrufe
I'm also a fan of the Templates in Quartus. With your HDL open, go to Edit -> Template -> VHDL and there are a couple RAM/ROM examples. You can paste them directly into your code.
995Aufrufe
I'm sorry! But I can't find "Template" in the "Edit" menu , also the focus on the VHDL file.
Indeed! I do not want just to achieve MEMORY,I just want Quartus to compilate my code to use the momory internal.
It seems that I only achieve it by creating new megafunction.
Thank you all the time!
995Aufrufe
The Edit menu is context sensitive, so it will only be there if you have a VHDL file open in the main window. If you're looking at a compilation report or something like that it won't be there. (Or you're using an older version of Quartus, but I'm pretty sure these are at least a year or two old). And using the code from the referenced manual will also work.
995Aufrufe
Thank you Rycs!
Thank you vernmid!
This way seems no way! I decide to achieve it by creating new megafunction.
995Aufrufe
Quartus language templates have been introduced with Quartus V7.1, I think. Code examples or also shown in the Quartus Handbook in the recoomend hdl coding styles chapter.
995Aufrufe
Hi ! That may be the problem , the version I used is V6.1 .
Thank you!
Antworten
