17253 Discussions
How can Quartus utilize all of the cores of CPU??
The same as the topic.
My PC has CPU -I7, 4G memory...
- You need a Quartus subscription license
- Under Tools/Options/General/Processing/Parallel Compilation, you can set the number of CPUs used for compilation.
I have got the license.
And also set the parallel compilation to "all available processors" :confused:
But it still use only one core.
My OS is windows sever 2003.
--- Quote Start ---
--- Quote End ---
I'm not a real OS expert, but did your OS recognize all your CPU's ?
Is Windows Server 2003 supported by QUartus ?
Kind regards
GPK
Did you check "Flow elapsed time" in compilation report?
--- Quote Start ---
--- Quote End ---
I have checked , when fitting the Quartus "average processors used" is 2.1:)
