I'm working on a project that requires me to improve on an already existing project. The contains this syntax
wire [15:0]music1=(instru)?music1_ramp:music1_sin; which is to choose between music1_ramp and music1_sin. I want to expand this in such a way that I can choose between more than two options (say five), please can anyone tell me a syntax I could use to do this as I am still new to the languageLink Copied
--- Quote Start --- I'm working on a project that requires me to improve on an already existing project. The contains this syntax wire [15:0]music1=(instru)?music1_ramp:music1_sin; which is to choose between music1_ramp and music1_sin. I want to expand this in such a way that I can choose between more than two options (say five), please can anyone tell me a syntax I could use to do this as I am still new to the language --- Quote End --- assign music1 = (instru1) ? music1_ramp: (instru2) ? music2_ramp: (instru3) ? music3_ramp: music5_sin; //default
You can also change the logic to use an always block if the conditional syntax gets unruly:
reg music1;
always @* begin
if(instru1) music1 = music1_ramp;
else if(instru2) music1 = music2_ramp;
else if(instru3) music1 = music3_ramp;
else if(instru4) music1 = music4_ramp;
else music1 = music5_ramp;
end
This should produce the same logic as the conditional but may be easier to read for some. Jake
