17254 Discussions
How to adjust bus width?
In my design, sometimes I need to adjust bus width such as:
wire [10:0] a;
wire [5:0] b;
assign b={a[10:9],a[3:0]};
I always program like this. But it seems in some design it will cause problem and there are some errors which I can't understand appear in ModelSim simulation.
I just wonder is there any other approaches to do bus width adjust which is better?
Thanks very much.
The syntax is correct. I used it in ModelSim, too, but I never had problems.
What do you mean with "some errors"? Compile or functional simulation?
Sorry Cris, actually I did not express exact. I just wonder whether this syntax may cause problem in static timing analysis? Based on my understanding, it should not since this is just connecting wire.
With functional simulation I indeed meant static timing analysis.
So the answer is still Yes: your syntax is correct. You probably have an error somewhere else.
Thanks very much, I will check.
