17255 Discussions
How to change signaltap trigger using TCL
I am using tcl to capture signaltap data.
The .stp file has a predefined trigger, based on a counter reaching a certain value.
I want to capture data for different counter values.
What I have so far:
open_session -name $signaltap_file run -hardware_name $usb_blaster -device_name $device -instance auto_signaltap_0 -data_log log_1
I am aware of the -trigger option for the run command, but I have no idea how to use it.
Any ideas?
SBoda
Did you found the solution ?
