17253 Discussions
How to change the processing speed of a design?
Hi, I want to change the processing speed of my design to be slower, how can I make it happen? :confused:For instance I want it to finish after exactly 10 ms?
I have checked the setting timing constraint option, but it doesn't help because my design is a counter which increments without caring about any clock.
It was done very fast, how can I know the exact duration it cost?:)
Tool: Quartus II Cyclone II FPGA starter Dev kit
You will need a clock to have a precise speed for your system. You can adjust its frequency through a pll or use clock enables to make your system run at a fraction of the input clock.
