17256 Discussions
How to control fan out of an asynchrounous signal
We had a design let say would be replicated more than 8000 times or would generate 8000 of fan-out for the reset signal.
Module:process(reset,clock)
Begin
If (reset=’1’) then
Some operation
Else if rising_edge(clock) then
Some operation
End if
End process Module
Had tried
force the signal to non global resource, -> causing that to failed for the recovery time.
Max_fanout setting used to control this net and duplicate the flip-flop. -> failed
This node feeds to an asynchronous control port -> attached is the picture.
For this case, can we still set false path in between the register? Or need rerouting? Or there is any assignment setting that need to set? To control the fan-out of an asynchronous signal in Quartus.
Thanks in advance for the help
Best regards
kenny
You didn't report, if you observed any problems, if you just let Quartus do it's work? I assume none.
Dear FVM,
Thanks for your response,
the Quartus shows “Warning: Ignored Maximum Fan-Out assignment”
We try use MAX_FANOUT setting to control the net and to duplicate the flip-flop driving this net. Unfortunately, this cannot be used because the node feeds to an asynchronous Control ports. You may refer to the picture above.
http://www.altera.com/literature/hb/qts/qts_qii5v1_03.pdf (http://www.altera.com/literature/hb/qts/qts_qii5v1_03.pdf) -> page 9-47
So how do we control the fan-out for an asynchronous signal in Quartus?
Thanks in advance,
Best regards
Kenny
Had tried also
PHYSICAL_SYNTHESIS_ASYNCHRONOUS_SIGNAL_PIPELINING & ASYNC_PIPELINE_REG_REACH setting to duplicate the source register but failed.
thanks
regards
kenny
Did you observe any real problems, besides the said warning?
Had tried send a mail, but i guess it failed to send. It initially failed for the recovery timing in Time Quest.
thanks
regards
kenny
Please excuse my penetrant asking, it wasn't actually clear to me. I think, it's not mainly a fanout problem rather than of achieving the correct timing for the reset signal along the clock path at a rather high clock frequency. Avoiding asynchronous controls for fast registers simplifies timing closure a lot. Do you really need an asynchronous reset?
To understand the Quartus behaviour with signal fanout, I set up a simple circuit with 8000 registers (simply connected as a shift register chain) and a reset synchronizer driving the asynchronous reset of each register.
With Cyclone III, Quartus used a global clock resource to connect the reset signal and had no problem to achieve 250 MHz clock rate.
Dear Fvm,
Thanks for your input, I am using Stratix II EP3SE110F78014 and the fan out is about 60000. The result show slack ~-0.7 and End Point TNS ~-4000.
By improving the TNS, I had tried to set the following
1) set the global signal to off in the assignment editor.
2) Increase the Effort level to Extra in the setting
3) Perform automatic asynchronous signal pipelining in the setting
And the result shows TNS ~-3000 in improvement. Is there anything that I can do to improve the TNS? I am following the guideline from the attached notes.
Thank for your patient and help.
Best regards
Kenny
After long reseach, Quartus does not encourage do reduce the max fan out. However, we can set some setting in the QSF file to control it:
set_instance_assignment -name ADV_NETLIST_OPT_ALLOWED "ALWAYS ALLOW" -to
set_instance_assignment -name MAX_FANOUT 500 -to
set_instance_assignment -name IGNORE_MAX_FANOUT_ASSIGNMENTS OFF to
set_instance_assignment -name IGNORE_MAX_FANOUT_ASSIGNMENTS OFF -to
set_global_assignment -name TIMEQUEST_MULTICORNER_ANALYSIS ON
set_global_assignment -name TIMEQUEST_DO_CCPP_REMOVAL ON
set_global_assignment -name PHYSICAL_SYNTHESIS_COMBO_LOGIC ON
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_RETIMING ON
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION ON
set_global_assignment -name PHYSICAL_SYNTHESIS_ASYNCHRONOUS_SIGNAL_PIPELINING ON
set_instance_assignment -name MAX_FANOUT 500 -to set_instance_assignment -name ADV_NETLIST_OPT_ALLOWED "ALWAYS ALLOW" -to
set_instance_assignment -name AUTO_GLOBAL_REGISTER_CONTROLS ON -to
