17249 Discussions
How to create a vector waveform file in quartus 11.0?
I can not find the location of vector waveform file in quartus 11.0. help me! This version is different from the 9.0!
  • This feature (embedded simulator) is obsolete in your current quartus ( version 11.0 ), that support has been removed.
  • So even if you have Quartus 9 project and now trying to open .vwf file in quartus 11.0,it will not be able to find that file.
  • Dragging that file into your project will open simple "text" but not waveform display.
So now i think you should use "Modelsim" for simulation.
Thanks for your answer! but I really need the vector waveform support!
If I use the " modelsim", it will be similar with waveform?
Can you help me more?
Best regard!
  • Yes similar waveform,in fact more than that,you can experiment and debug in it.Plenty of options it has.
  • You only need to create test bench (giving inputs) and simulate it.
  • Better you search for this.You will find this pretty easy.
Sample Websites for quick and easy learning about testbench :
  1. http://www.asic-world.com/verilog/art_testbench_writing.html
  2. http://www.cecs.csulb.edu/~rallison/verilog_examples_table.htm (http://www.cecs.csulb.edu/%7erallison/verilog_examples_table.htm
You can find also "Modelsim" tutorials about simulation.
thanks alot! I am trying it! Hope you can help me more if i have problems with it!
