17268 Discussions
How to develop a Verilog model for a peak detector?
Develop a Verilog model for a peak detector that finds the maximum value in a sequence of 10-bit unsigned integers. A new number arrives
at the input during a clock cycle when the data_en input is 1. If the new number is greater than the previously stored maximum value, the maximum value is updated with the new number; otherwise, it is unchanged. The stored maximum value is cleared to zero when the reset control input is 1. Both data_en and reset are synchronous control inputs.
Please help, thanks!
Homework?
module peak_detect( input wire clk, input wire reset, input wire data_en, input wire in, output reg peak ); always @ (posedge clk) if (reset) peak <= 0; else if (data_en && (in > peak)) peak <= in; endmodule
Cheers,
Alex
--- Quote Start ---
Homework?
Cheers,
Alex
--- Quote End ---
Thanks Alex.... i got it done yesterday... thanks anyway :)
--- Quote Start ---
Homework?
Cheers,
Alex
--- Quote End ---
Hey Alex... do you know how to detect several peaks?
