17268 Discussions
How to drive Global TMR clock-tree networks correctly in Altera FPGA?
I am exploring a range of techniques to implement TMR clock trees as part of a global TMR design (all resources including i/o pins, clock trees, reset trees, logic and registers are implemented with triple redundancy). As I am not interested in being locked into any vendor's automated GTMR tools, I'm looking to do this by hand. My understanding is that GTMR is required in FPGA because a single-event-upset SEU in the CRAM bits of a SRAM based FPGA could disconnect the clock tree from a large portion of the logic that it was driving...
I observe the difficulties with the following 3 approaches on an Altera Cyclone V SE:
1) Altera's Cyclone ALTPLL can generate up to 6 clock outputs from one clock source. It is technically possible to request 3 output clocks, each output clock driven at the same target frequency, duty cycle and phase offset. Unfortunately the redundancy is "optimised away" by the fitter tool, resulting in only a single global clock tree being driven. Can someone propose how to prevent this optimisation? --> Yes, it is probably better to have three ALTPLL.. please see approach 2. However, approach 1 would be interesting to explore jitter between driving registers from 3 different clock networks using this approach.
2) In true GTMR fashion, lets assume we use three input clock pins, each input clock pin driving its own pair of {ALTPLL, ALTCLKCTRL} modules. With a rather generous application of guidance to the tools (e.g. syn_keep/syn_noprune/.. like controls), it is possible to drive three global clock tree networks with 3 different PLL operating at the same speeds. I have setup a very simple timing harness (1 data input pin drives a shift register of 10 bits. Those 10 input bins are xored onto the state of 2x 10 bit shift register driving, each shift register driving one data output pin. The three shift registers are all driven by their own clock pin (pin_m?_clock)). With this simple test scheme in place, TimeQuest Timing Analyzer "setup summary" complains that:
pin_m0_clock slack: 0.650 End Point TNS: 0.000
pin_m1_clock slack: -0.877 End Point TNS: -7.575 (flagged as an error)
pin_m2_clock slack: -0.855 End Point TNS: -7.9641 (flagged as an error)
I'm not sure what is required to address these errors in a safe way.
3) If we use three input clock trees, and each clock pin directly drives its own ALTCLKCTRL module, it is possible to drive three global clock tree networks from 3 chip pins (presumably driven by a single clock source operating at the same speed). Using the same test harness described in (2) above, TimeQuest Timing Analyzer does not make any complaints. There is around -0.339 (m0_clock->m1_clock) to -0.583 (m0_clock->m2_clock) clock skew. I note that clock control for M0 and M1 are located physically close together on the middle-left-edge of the chip, where the third clock control for M2 is located on the middle-bottom edge of the chip and may explain some of the difference in skew (339 vs 583). As an related item, I implemented a single-clock version of the same test harness to check for clock-skew between registers on the same clock.. and it was down to -0.071. I'm hoping there is some way to significantly reduce that >300 skew down to something much lower. (My understanding is at least one of the primary goals of reducing the jitter between the TMR clock-trees is to prevent metastability problems on the feedback loop of TMR finite state machines [ loopback -> voter -> FSM logic -> D-FF -> loopback ].)
I'd be interested to hear advice on how to improve this (3)rd approach. I am not sure exactly what the pro's/con's of driving the global clock networks *directly* from the pins are, but it seems like approach (2) above would be better if the errors reported in (2) could be overcome.
I appreciate all input, guidance and advice on how to correctly do / optimise any of the above three manual approaches. Please feel free to propose a even better manual approach for on-chip global TMR.
The Happy Techy
