17268 Discussions
How to shift left 4bit signal without making register
Hi
I need to create component witch work like shift register for 4 bit signal . How can I do that?
Got a favourite language? In VHDL you could do something like:
b <= b(2 downto 0) & '0';
assuming b is defined as a four bit std_logic_vector.
Mark.
you could do that, but it wont work without registers. Its called a shift register for a reason...
--- Quote Start ---
--- Quote End ---
Well, yeah, the behaviour of that line of code is entirely dependent on what's around it. On it's own it doesn't hold a value or anything. The OP's question was a little vague...
Mark.
Thank you for answer!!!
