17268 Discussions
How to simulate ip's generated by the HLS in the Active HDL
DKras4
I have a project build in Active HDL.
I want to use ip's that is generated by the HLS in this project.
Where is the BEH files that should be used by Active HDL?
KennyTan_Altera
Can you used Modelsim instead? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-getting-started.pdf
Currently our user guide show for Modelsim. If you want to use activa HDL, you will have to follow the steps like the modelsim and see if you face any problem using it.
