The new version Quartus II has removed the vwf file, the simulation need to be done through third party tool like Modelsim. If I do a design through schematic design, how can I simulate it through Modelsim? As I know, Modelsim can only simulate HDL designs.
One approach seems to be using Quartus II to transfer schematic design to HDL design, then simulate the HDL in Modelsim, I just wonder whether there is other approach? Thanks very much.Link Copied
Conversion to HDL is the only choice if you want to simulate an RTL design. You can compile the design and create a post P&R netlist to simulate, but this is much slower.
The best option may be to forget about schematic altogether and just write the whole thing in HDL in the first place.- Mark as New
Got it, thanks very much!
This might be useful for you:
"I put together a little TCL script that automatically converts a schematic top-level entity to Verilog to help streamline preparation for ModelSim. " http://www.alteraforum.com/forum/showthread.php?t=36262&highlight=tcl+macro+for+top-level+schematic+to+verilog+conversion- Mark as New
Thanks very much, czeh!
There is a program that you can create a waveform for your design like older versions of quartus.its name is "altera upds". you can simulate your schematics with it easily.
Thanks, where can I get it?
Another option is to stick with Quartus2 Version 9.1, unless you need the latest features. At least Version 9.1 runs with Win7 64 bits.
Yes, that is another approach. Thanks
