17267 Discussions
How to use Radio Display_Hint in hw.tcl file
In the Quartus II Handbook Version 9.0 there is a nice example of how to create a pull down menu using allowed_ranges
add_parameter sound string 0 0
set_parameter_property sound allowed_ranges {"0:No Audio" 1: Monophonic 2:Stereo 4:Quadraphonic}
When I do this, I get a nice pulldown menu that assigns sound a value of 0,1,2, or 4 but displays the text instead of the number.
I had wanted to use this syntax with a
set_parameter_property separate_control DISPLAY_HINT radio
But when radio hint is used; 0, 1, 2 and 4 are displayed without any text.
Does anyone know how to show the nice text strings in the radio format but assign the numberic value to the string for easy use assigning a number value later.
I ran into that too. Instead what I did was used a dummy string parameter then took the result and mapped that to my integer parameter in .tcl You have to do this in the validation callback.
If you want to see an example shoot me over an email and I'll send you my .tcl file.
I will make a dummy string or stick with the pull down.
-Jennifer
