17245 Discussions
How to use <ALTERA_NOTE> section for NIOS II simulation
Now I am trying Nios II simulation using ModelSim.
ModelSim is started by Run of Eclipse.
Before adding code to <ALTERA_NOTE> section, it works well.
I want to add some RTL code (including additional logic module).
additional modules are stored in different directory from Simulation directory.
I used menu of File > Source Directory to add location of new module .v files.
But I am facing following error.
** Error: (vsim-3033) ../xxx.v(14053): Instantiation of 'yyy' failed. The design unit was not found.
Does somebody know how to add additional module to ModelSim.
My environments are
Quartus II 11.0 Web Edition (32-Bit)
Nios II 11.0 Software Build Tools for Eclipse
ModelSim-Altera 6.6d (Quartus II 11.0) Starter Edition
Thank you.
Hi
I understood that I can resolve this problem by adding include sentence to <ALTERA_NOTE> section at the out of testbench.
Thank you.
