17252 Обсуждение
How to use wildcard to report all timing path in TimeQuest
NuvKFC
Новый участник I
1 187Просмотр.
Following picture shows the design.
Due to lacking of clock, the design use LCELL to generate a pulse to wake up  system clock.
The design:
I use follow command to report the delay between LCELLs because I had constrained "set_min_delay" as follows.
constraint:
set_min_delay 0.5 -from [ get_pins {top|IP_*|Inp_dly*|dly*d|combout}] \
                                  -to      [ get_pins {top|IP_*|Inp_dly*|dly*d|data*}]
report command:
report_path -from [ get_pins {top|IP_*|Inp_dly*|dly*d|combout}] \
                       -npaths 1000 -panel_name LCELLs_delay
After using the report command in TimeQuest, there only report the delay from "Inp_dly1|dly1d|combout" to "Inp_dly2|dly4d|data*".
How to report all delay between LCELLs?
Thank you very much.
0 баллов
1 Решение
RichardTanSY_Altera
Модератор
1 172Просмотр.
The report_path reports the longest delay paths and the corresponding delay value. That could be reason why only path from "Inp_dly1|dly1d|combout to "Inp_dly2|dly4d|data*" is reported.
Try to specify the start and end point if want to check the delay between the specific LCELL.
Reference: https://www.intel.com/content/www/us/en/docs/programmable/683432/21-3/tcl_pkg_sta_ver_1.0_cmd_report_path.html
Просмотреть решение в исходном сообщении
6 Ответы
RichardTanSY_Altera
Модератор
1 173Просмотр.
NuvKFC
Новый участник I
1 165Просмотр.
Hi RichardTanSY_Intel
    Oh, I get it. Thank you, RichardTanSY_Intel, so much.
Can I ask another question?
You said that "specify the start and end point if want to check the delay between the specific LCELL."
Could I use "report_path" command twice to report the delay into the same panel?
Ex.
(1)
report_path -from [ get_pins {top|IP_1|Inp_dly1|dly1d|combout}] -to [ get_pins {top|IP_1|Inp_dly1|dly2d|data*}]
(2)
report_path -from [ get_pins {top|IP_1|Inp_dly1|dly2d|combout}] -to [ get_pins {top|IP_1|Inp_dly1|dly3d|data*}]
There use "report_path" command twice.
Could the second  "report_path" command report the delay that append into the same "LCELLs_delay" panel, but not overwrite?
RichardTanSY_Altera
Модератор
1 162Просмотр.
You can use the report_path command multiple time but you will need to use a different panel name else it will be overwritten.
NuvKFC
Новый участник I
1 157Просмотр.
    OK, I understand it. Thank you, RichardTanSY_Intel, so much.
RichardTanSY_Altera
Модератор
1 149Просмотр.
I’m glad that your question has been addressed. With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
NuvKFC
Новый участник I
1 083Просмотр.
    OK. Thank you, RichardTanSY_Intel, so much.
Ответить
