17253 Discussions
How to write the 125 Mhz frequancy in a testbench vhdl language
I'm beginner in VHDL,
I have to devide the frequency from 125 Mhz to 1 Hz
for that I used this code to generate the 1s clock
--- generate the 1s clock ---
process(clk,rst)
begin
if rst='1' then
cnt<=1;
else
cnt<=cnt+1;
end if;
if cnt<=62000000 then
clk_s<='0';
else
clk_s<='1';
end if;
if cnt=125000000 then
cnt<=1;
end if;
end process;
the probleme is what's the value of clock (clk) I should define in testbensh ( is it 8ns ??)
help me please! thank you.
Abdallah.
--- Quote Start ---
process(clk,rst)
begin
if rst='1' then
cnt<=1;
else
cnt<=cnt+1;
end if;
clk_s<='0';
else
clk_s<='1';
end if;
cnt<=1;
end if;
end process;
Abdallah.
--- Quote End ---
in your testbench just write:
clk <= not clk after 4 ns;
thank you kaz
ok now i'm sure about the 8ns.
but the simulation dont provide result of 1s in the clock_s but it provide result of 0.5 s
is the problem in the value of the counter?!!
thanks!
--- Quote Start ---
thank you kaz
thanks!
--- Quote End ---
your counter need to run from 0 to 125000000-1 freely
you set logic to zero or one when count = [0, 125,000,000/2 -1] respectively, or so depending on duty cycle.
process(rst,clk) begin if rst = '1' then count <= 0; elsif rising_edge(clk) then if count = 125000000-1 then count <= 0; else count <= count +1; end if; if count = 0 then clk_1s <= '0'; elsif count = 125000000/2 -1 then clk_1s <= '1'; end if; end if; end process;
your simulation may get too long, you may scale it down by factor.
You also need clock edge
