How use sram?
I must use the sram on fpga Cyclone ii with quartus ii.
How can i use it?
I have used the megafunction but i don't see in the istantion the chip enable, read enable and other signals.
Is there a component in a specific library for the use of sram?
Thank you!
baghiero83:
--- Quote Start ---
How can i use it?
--- Quote End ---
I suppose you are trying to use the Cyclone II on-chip memory.
The MegaWizard is an efficient tool to generate a specific RAM for you. The RAM block at least has both an input port AND an output port. You only need a signal wren for writing. Reading is always done on every clock cycle.
The signals you are refering to are signals that occur when you are sharing the input- and output lines of your RAM. By making a wrapper arround the MegaWizard RAM block you can constrain yourself to only using one port for both reading and writing that you can then interface via an external tri-state bus. Internally on the FPGA I do not see the usage of this.
Thanks, so i can't use the chip enable because the ram is always enabled?
Are you sure that when i use megawizard ram , i use sram and not sdram on-chip?
How can i constraint myself to using one port?
Thank you very very much!
baghiero83:
--- Quote Start ---
--- Quote End ---
The Ram is always enabled. If you want a chip enable, you have to add it yourself.
--- Quote Start ---
--- Quote End ---
On a normal CMOS chip you normally only have SRAM blocks. The Block RAMs on FPGAs are SRAM. DRAM requires a special technology that is not compatible with normal CMOS technology. So there are no DRAMs on FPGAs up to now. DRAMs are separate chips.
--- Quote Start ---
--- Quote End ---
I do not understand why you would like to do this on-chip of the FPGA?
1) Do you want to access the FPGA on-chip memory from outside?
2) Do you want to access of-chip memory from your FPGA
The out bitstream of the sram must be the input of a Flip flop chain
So, On chip
but i want also read with an oscilloscope the out bitstream of the sram
