17267 討論
I am using Intel IP components. I used quartus to create the ModelSim script to compile the design. When ModelSim attempts to start simulation, I get Errors for all the Intel IP as shown in the details section.
CHatz
新手
2,693 檢視
# ** Error: (vsim-3935) C:/Projects/A10_BSM/BSM_EPL_PCL_EGL/simulation/modelsim/../../new_ip/CCP_RAM/sim/CCP_RAM.vhd(45): Port 'A_IN' not found in the connected module.
#  Time: 0 ps Iteration: 0 Instance: /bsm_epl_pcl_egl_bsf_tst/uut/b2v_inst45/b2v_inst3/b2v_inst136/ram_1port_0 File: C:/Projects/A10_BSM/BSM_EPL_PCL_EGL/simulation/modelsim/../../new_ip/CCP_RAM/ram_1port_180/sim/CCP_RAM_ram_1port_180_iletabi.v
0 積分
3 回應
AnandRaj_S_Intel
1,394 檢視
Can you share more information On IP used & its Configuration, Quartus and modelsim tools version used in your design process?
Are you trying to simulate single IP or complete design?
Share transcript of modelsim.
Make sure appropriate version of Quartus tools and modelsim are used.
Example if you use Quartus 18.0 you need to use modelsim 10.6c if Quartus 17.0 use modelsim 10.5b.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
CHatz
新手
1,394 檢視
Hello Anand,
I am using the Quartus 18.0 package. This package came with the ModelSim 10.5b version and that's the version I am using to
simulate.
I am simulating a complete design containing Intel IP and custom components.
Unfortunately, the Intel Web Site won't allow me to upload the files.
Costas Hatzinikolaou,
Sperry Rail Corporation.
CHatz
新手
1,394 檢視
Adding the libraries in the top level file, eliminates the Errors:
--edits for simulation
library altera_mf;
use altera_mf.all;
library altera;
use altera.all;
回覆
