17268 Discussions
Implementing in BRAM using Megawizard
I need help in megafunction. how to instantiate the megafunction in the Verilog code.
Once you have the megafunction generated, you can instantiate it like any other verilog module.
Usually one of the files generated is either a verilog file, or black box with the port definitions. You just the same port calls and include the qip file as part of the syntheis stage.
Usually they also have a .vo file for simulation. So you can simulate the design with that.
Pete
Thank you.
