17252 Discussions
Importing EDIF To Quartus project
I am new to quartus and FPGA implementation. I was given some EDIF files, and want to import them to my project. I was about to go to "Add Files" and point to the EDIF file, but what am I supposed to do next.
The EDIF is of an IP core that has I/O Pins, so I would like to map them in the Pin Planner to the pins I have on my development kit. Please someone guide me how to proceed.
Quartus' help offer some info here. Refer to the "edif input file (.edf) (http://quartushelp.altera.com/14.1/mergedprojects/reference/glossary/def_edf.htm)" section.
Assuming you are able to run the code through Quartus you will then be able to use the Pin Planner to assign all the I/O.
Cheers,
Alex
