17268 Discussions
In-system memory content editor cannot read/write to RAM
The In-system memory content editor cannot read or write a RAM that was instantiate for the IP core library.
The RAM (altsyncram) concerns a single port configuration. Read and write commands from other (own) blocks is going well, but the content editor gives a depth of 0 addresses of the RAM.
I have already added the default parameter: CYCLONEIV_SAFE_WRITE RESTRUCTURE, but it didn't work out anything.
In the RTL and technology viewer, the RAM block is connected to the JTAG logic.
Used soft- and hardware:
Quartus II Version 14.1.0 Build 186 12/03/2014 SJ web edition
DE0-nano / FPGA: EP4CE22F17C6
VHDL code:
altsyncram_component : altsyncram GENERIC MAP ( clock_enable_input_a => "BYPASS", clock_enable_output_a => "BYPASS", intended_device_family => "Cyclone IV E", lpm_hint => "ENABLE_RUNTIME_MOD=YES,INSTANCE_NAME=RAM", lpm_type => "altsyncram", numwords_a => 32, operation_mode => "SINGLE_PORT", outdata_aclr_a => "NONE", outdata_reg_a => "UNREGISTERED", power_up_uninitialized => "FALSE", read_during_write_mode_port_a => "DONT_CARE", widthad_a => 5, width_a => 8, width_byteena_a => 1 ) PORT MAP ( address_a => address, clock0 => clock, data_a => data, wren_a => wren, q_a => sub_wire0 );
Anyone an idea why I cannot read/write with the in-system memory content editor?
Thank you in advance,
Rutger
Do you have a jtag Avalon master connected to what you are trying to modify?
Yes I have, the In-system memory content editor can scan the JTAG chain with the USB-blaster. The DE0-nano is connected with the USB cable to my PC.
When i instantiate some LPM constants, I can proper read and write these constants with the content editor.
The problem is not the connection (I thing) but the In-system memory content editor says that the dept of the RAM is 0 (should be 2^5, see code above).
Usually I would use Qsys onchip-memory to instantiate my altsyncram with in-system memory editor turned on.
Anyway, can you try changing the instance name to something unique? ie
lpm_hint => "ENABLE_RUNTIME_MOD=YES, INSTANCE_NAME=RAM_101_INSYSTEM",
I have tried it, but the result is the same.
Could you check whether did Quartus optimize your RAM to be MLAB? Sometimes because your memory is too small and able to fit into a MLAB, quartus will convert it for you.
Can you humor me by setting the ram block type? ie
ram_block_type => "AUTO", or ram_block_type => "M9K",
I have tried both, but it didn't work out.
The MLAB configuration is not supported by the Cyclone IV FPGA.
When type is set to auto, the M9K is also instantiated.
