17267 Discussions
In system memory content editor
I have a design with 2x the same modules , e.g MA and MB.
These modules containa a Ram RA.
With the Mega Wizard I can specify the Instance ID of the Ram.
If I specify the Instance ID as RA1 of module MA . and
specify the Ram of the MB module ad RA2.
I see only RA2 in the "In system memory content editor".
How can I see them both?
regularly, the editor shows all existing instances, when you scan the device. You can select one at a time to communicate with. You should first check in compilation report if both instances actually have been created. The memory instances must have an unique numeric instance ID in addition to the displayed name, but with default settings it is choosen automaticly. You can see this also from the report.
Frank
I can's see the instance ID in the compilation report.
In the RAM summay of the Analysis & synthesis report I see the instantiation of the 2 RAMs but not a special ID number.
I did change the RAM ID but in the In system memory editor i see the RAMID name of an older run with 1 RAM, and I don't see the 2 ram ID's of the new run with 2 RAM's.
I don't get rit off the old ID name.
Wim
I thought it could be that the in-system memory content editor window shows outdated info, as it could happen with source&probe tool. But I saw, that when you perform a scan chain, you get always an updated display of all existing memory instances, respectively No Instances Found. So I think the only way to see outdated instance info is that the most recent compilation result wasn't loaded to FPGA. This could happen e. g. if you once selected a different *.sof file in JTAG Chain Confuguration or the JTAG configuration was overwritten from a different configuration source also in effect.
Frank
I have find out that First you need to program the FPGA with the programmer itself and not to try to program it with the In System Merory Content Editor as can be done with Signal- tap tool.
I find now 2 RAMS with index 0 and 1.
Thanks for you help
Regards Wim
