17268 Discussions
Including Files in Verilog
I am a noob at Quartus. I have a large chunk of a very large ASIC design that I want to implement in an FPGA. The design to be implemented is spread across several directories.
I cannot get Quartus to recognize any of the verilog include files. The .vh files are in the same directory as the files that call them. I tried
set_global_assignment -name SEARCH_PATH "full path"
in the .tcl file, but it has no effect.
Any advice?
--- Quote Start ---
Any advice?
--- Quote End ---
Use Tcl to create the absolute path name of the file, and then use that in the Quartus assignment:
set_global_assignment -name VERILOG_FILE $full_path_to_file
Given the top-level directories where your ASIC source is located, you can use Tcl glob to automate listing of all the Verilog files.
Cheers,
Dave
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
Ok, I did say I was a noob. What is the tcl command to get the absolute path name? BTW I already tried adding these files to the compile list in Quartus. It didn't change anything.
Mike
I tried:
set my_path file join root_of_path tail_of_path
set_global_assignment -name VERILOG_FILE $my_path
This has no effect. I tried it with just the path, and with the file name.
Mike
Hi Mike,
--- Quote Start ---
I tried:
--- Quote End ---
There's examples of how to script Quartus in this tutorial:
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial
If you look at one of the synthesis scripts, eg.,
altera_jtag_to_avalon_mm_tutorial\hdl\boards\bemicro_sdk\qsys_system\scripts\synth.tcl
you'll see an example of how the script determines the path to the tutorial source, and then uses absolute paths in the subsequent assignments.
Cheers,
Dave
