Hi
When I run a design through GUI, STA reported a Fmax of 680 MHz for a post-map netlist. When I ran the same design through command line, STA reported an Fmax of 86 MHz. commands are: quartus_map --64bit system_dp_256_script.qsf quartus_sta --64bit system_dp_256_script --post_map --do_report_timing --sdc=system_dp_256_script.sdc Post-map resources are same in the both the cases. If I try running STA on post-fit netlist, Fmax reported in the flows are consistent. Am I missing any arguments in command-line mode? RegardsLink Copied
Did anyone else face similar problem?
