17249 Discussions
Incremental Compilation Issue
I am trying to shorten my compilation by using incremental compilation but I don't think it's working. I think it's re-compiling my fft module every time, despite my not making any changes to it.
In my design, I am using the FFT v2.1.1 MegaWizard Plug-in. I have figured that this module is probably taking up a lot of the compilation time, and since I never make any change to it, I can speed up the compilation process by setting it as a design partition and using incremental compilation.
I have full incremental compilation turned on, I've set the fft instance as a design partition in the Project Navigator window, and I've set each partition's Netlist Type to Post-Fit. However, the compilation time is not reduced and messages in the processing tab indicate to me that it is re-compiling the fft module. If I don't make any changes to the design, the re-compilation is instantaneous. But if I make a slight change, it re-compiles my whole design. It is as if the incremental compilation is working but the design partitions are being ignored.
I have three design partitions: the whole project, an instance of my design, and the fft instance. The compilation time is about 40 minutes.
Hi ferus,
To find out why partitions aren't being preserved, there are a few report panels to check:
1) The Fitter report includes panels called "Preservation Summary" and "Partition Settings" which breakdown on a per-partition basis how much was preserved. It also shows what the requested netlist-type was for each partition and what was actually used.
2) The Synthesis report includes a panel called "Dependent Source Files" for each partition along with which one it detected as changed. This can help you narrow down why a partition was re-synthesized.
