17254 Discussions
Info: Pin qB han GND driving its datain port
Hello!
I am new in Altera and this is my first program.
Our task is to program the structural diagram (copying the logic diagram) of 74192 IC -- that is, SYNCHRONOUS 4-BIT UP DOWN COUNTER.
We also need to show the waveform diagram of the program and should look like what is in the datasheet.
My problem is it does not do what it should suppose to do and i've checked it many times.
I think, Info: "Pin qB has GND driving its datain port" and "upA is an undefined clock" causes the error (from the warning).
This is my code. Please help me guys :(
My reference datasheet: http://physics.gac.edu/~huber/classes/phy270/specsheets/74192.pdf
module srFlipFlop(q,q1,r,s,clk);//(q,r,s,clk,reset)
output q,q1;
input r,s,clk;
reg q,q1;
initial
begin
q=1'b0;
q1=1'b1;
end
always @(posedge clk )
begin
case({s,r})
{1'b0,1'b0}: begin q=q; q1=q1; end
{1'b0,1'b1}: begin q=1'b0; q1=1'b1; end
{1'b1,1'b0}: begin q=1'b1; q1=1'b0; end
{1'b1,1'b1}: begin q=1'bx; q=1'bx; end
endcase
end
endmodule
module PrelimProjectStructural(a, b, c, d, downA, upA, clr, load, bo, co, qA, qB, qC, qD);
input a, b, c, d, downA, upA, clr, load;
output bo, co, qA, qB, qC, qD;
wire notUp, notDown, notClr, notLoad;
wire wSA, wRA, wTA, wQA, wQ1A, wSB, wRB, wTB, wQB, wQ1B, wSC, wRC, wTC, wQC, wQ1C, wSD, wRD, wTD, wQD, wQ1D; //rsff
wire wAndDA, wAndDB, wAndDC, wNandDA, wNandDB, wOrDA, wOrDB;
wire wAndCA, wAndCB, wNandCA, wNandCB, wNandCC, wOrCA, wOrCB;
wire wAndBA, wAndBB, wNandBA, wNandBB, wOrBA, wOrBB;
wire wNandCo, wNandBo;
//nots
not(notUp, upA);
not(notDown, downA);
not(notClr, clr);
not(notLoad, load);
// q'
//not(wQ1A, wQA);
//not(wQ1B, wQB);
//not(wQ1C, wQC);
//not(wQ1D, wQD);
//Part D
and(wAndDA, notUp, wQC, wQB, wQA);
and(wAndDB, notUp, wQD, wQA);
and(wAndDC, wQ1C, wQ1B, wQ1A, notDown);
nand(wNandDA, notClr, notLoad, d);
nand(wNandDB, notLoad, wNandDA);
or(wOrDA, wAndDA, wAndDB, wAndDC);
or(wOrDB, ~notClr, ~wNandDB);
//Part C
and(wAndCA, notUp, wQB, wQA);
and(wAndCB, wQ1B, wQ1A, notDown, wNandCB);//
nand(wNandCA, notClr, notLoad, c);
nand(wNandCB, wQ1D, wQ1C, wQ1B);
nand(wNandCC, notLoad, wNandCA);
or(wOrCA, wAndCA, wAndCB);
or(wOrCB, ~notClr, wNandCC);
//Part B
and(wAndBA, notUp, wQ1D, wQA);
and(wAndBB, wNandCB, wQ1A, notDown);
nand(wNandBA, notClr, notLoad, b);
nand(wNandBB, notLoad, wNandBA);
or(wOrBA, wAndBA, wAndBB);
or(wOrBB, ~notClr, wNandBB);
//Part A
wire wNandAA, wNandAB, wOrAA, wOrAB;
nand(wNandAA, notClr, notLoad, a);
nand(wNandAB, notLoad,wNandAA);
or(wOrAA, notUp, notDown);
or(wOrAB, ~notClr, ~wNandAB);
//others
nand(wNandCo, notUp, wQD, wQA);
nand(wNandBo, wQ1D, wQ1C, wQ1B, wQ1A, notDown);
//flip flops
// q,q1,r,s,clk
srFlipFlop srD(.q(wQD), .q1(wQ1D), .r(wOrDB), .s(~wNandDA), .clk(~wOrDA));
srFlipFlop srC(.q(wQC), .q1(wQ1C), .r(wOrCB), .s(~wNandCA), .clk(~wOrCA));
srFlipFlop srB(.q(wQB), .q1(wQ1B), .r(wOrBB), .s(~wNandBA), .clk(~wOrBA));
srFlipFlop srA(.q(wQA), .q1(wQ1A), .r(wOrAB), .s(~wNandAA), .clk(~wOrAA));
// output bo, co, qA, qB, qC, qD;
assign bo = wNandBo;
assign co = wNandCo;
assign qA = wQA;
assign qB = wQB;
assign qC = wQC;
assign qD = wQD;
endmodule
