17254 Discussions
Installation of 10.1_quartus_free_linux.sh on Ubuntu 10.04
Hey,
I have been trying to install the 10.1 free version of quartus on the Ubuntu 10.04 32bit
The installation for Quartus succeeds but then it fails when trying to install the Device families.
I have been running the following command and havent patched the install file
bash ./10.1_quartus_free_linux.sh
Before this I have tried
bash ./10.1_quartus_free_linux.sh --no-exec
There is no libX11.so.* in the 10.1_quartus_free_linux.sh/altera_installer/bin directory
As such I thought that the installation would succeed.
The installation proceeds halfway with QPixmap warnings. Then when trying to install some family of devices it fails. I have attached a sample error log.
Installing Arria II GX Family ... >>> Starting subprocess: /home/chiraag/altera/10.1/quartus/bin/quartus_sh --qinstall -qda "/home/chiraag/ddp/quartus/10.1_quartus_free_linux/altera_installer/bin/../../devices/subscription/arriaii.qda" -show_qt_progress >>> quartus_free install process 20436 finished with status 2 export: 137: 1200.00: bad variable name QObject::setParent: Cannot set parent, new parent is in a different thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread altera_installer_gui: Fatal IO error: client killed
After the this the GUI installer crashes. Reading the contents of the /tmp/altera_setup.log gives:
./altera_installer/setup: line 59: exec: altera_installer_cmd: not found
Note: Running multiple runs of the installer, I have noticed that it fails on different device families.
Any suggestions?
The link is not clear, can you post the full link
--- Quote Start ---
--- Quote End ---
Oops, a copy didn't work ../
http://www.alteraforum.com/forum/showthread.php?t=24563&highlight=ubuntu (http://www.alteraforum.com/forum/showthread.php?t=24563&highlight=ubuntu)
I think the problem in usage dash as shell in scripts. I changed link /bin/sh from "dash" to "bash" and installation pass well.
I cannot speak from experience, but I can confirm from conversation with other users alsilen's post regarding changing the shell from dash to bash in the scripts.
I solved this problem. you must install the ´flashplugin-install´ which the altera_installer_gui needed, I guessed that it really required the adobe flasher supported.
I have install "flashplugin-install",and when I run setup from 11.1_173_acds_devices.iso, Consol output those message:
*** glibs detected *** altera_installer_cmd : double free or corruption(fast top):0x0a24bf78 ***,and the install gui paused,,,,,,,
OS: RHEL 5.2
