17255 Discussions
Internal Error: Sub-system: CDB_SGATE, File: /quartus/db/cdb_sgate/cdb_sgate_component.cpp, Line: 93
sukesh
Hi, I am working on Quartus Prime pro 20.3 version. The Device I am working with is Arria10. I am facing the internal error while compiling the project. The Analysis and Synthesis runs initially after reaching a particular percentage of compilation a pop-up window indicating following errors.
Problem Details
Error:
Internal Error: Sub-system: CDB_SGATE, File: /quartus/db/cdb_sgate/cdb_sgate_component.cpp, Line: 931
Port direction does not agree.
Stack Trace:
Quartus 0x7011b: CDB_SGATE_COMPONENT::retrieve_known_port + 0x23b (db_cdb_sgate)
Quartus 0x5eeb8: qis_get_component_ports + 0x118 (synth_qis)
Quartus 0x5bcba: QIS_RTL_STAGE::IMPL::merge_nodes + 0x6ba (synth_qis)
Quartus 0x5c7be: QIS_RTL_STAGE::IMPL::merge_sgate_models + 0x36e (synth_qis)
Quartus 0x56f52: QIS_RTL_STAGE::IMPL::dissolve_partition + 0x3b2 (synth_qis)
Quartus 0x66ff0: QIS_RTL_STAGE::IMPL::uniquify + 0x9f0 (synth_qis)
Quartus 0x68108: QIS_RTL_STAGE::IMPL::uniquify + 0xc38 (synth_qis)
Quartus 0x21c8d: qis_uniquify + 0x1ed (synth_qis)
Quartus 0x16442: TclNRRunCallbacks + 0x62 (tcl86)
Quartus 0x17c4d: TclEvalEx + 0x9ed (tcl86)
Quartus 0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
Quartus 0xa5136: Tcl_EvalFile + 0x36 (tcl86)
Quartus 0x15246: qexe_evaluate_tcl_script + 0x4e6 (comp_qexe)
Quartus 0x1413b: qexe_do_tcl + 0x46b (comp_qexe)
Quartus 0x1a70e: qexe_run_tcl_option + 0x5ee (comp_qexe)
Quartus 0x146b1: QCU::DETAIL::intialise_qhd_and_run_qexe + 0xa1 (comp_qcu)
Quartus 0x1f8d2: qcu_run_tcl_option + 0x2f2 (comp_qcu)
Quartus 0x12cc: qsyn2_tcl_process_default_flow_option + 0x1dc (quartus_syn)
Quartus 0x1a00b: qexe_run + 0x3eb (comp_qexe)
Quartus 0x1b14a: qexe_standard_main + 0x26a (comp_qexe)
Quartus 0x2fe9: qsyn2_main + 0x129 (quartus_syn)
Quartus 0x167e8: msg_main_thread + 0x18 (CCL_MSG)
Quartus 0x17001: msg_thread_wrapper + 0x71 (CCL_MSG)
Quartus 0x21610: mem_thread_wrapper + 0x70 (ccl_mem)
Quartus 0x14b7d: msg_exe_main + 0x20d (CCL_MSG)
Quartus 0x4c38: __scrt_common_main_seh + 0x11c (quartus_syn)
Quartus 0x17613: BaseThreadInitThunk + 0x13 (KERNEL32)
Quartus 0x526a0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: qpro
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.3.0
Build: 158
Edition: Pro Edition
Kindly help me find the issue here. I am not sure whether it is due to HDL Error (but I did not see any errors in message window, but synthesis fails) or a system issue?
Thanks in advance.
RichardTanSY_Altera
I haven't seen this internal error before. Could you help to share your design .qar file (Project> Achieve Project) that could duplicate this error?
We will need to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
If possible, try to upgrade to the latest Quartus Pro version 22.4 to check if the issue persists, as a lot of bug has been fixed since then.
I found a similar thread but not sure if it helps.
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Quartus-Prime-Pro-19-2-quits-unexpected-with-following-error/m-p/646439
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
sukesh
Hi Richard,
Attaching the archived project for your reference.
RichardTanSY_Altera
I upgraded the design to Quartus 22.4 (with IP upgraded) and no IE occur anymore but error pop up at Analysis & Synthesis instead.
Error: REFCLK port on the PLL is not properly connected on instance i_M_MarlinHps|mm_video_mux|mm_video_mux|lcd_lvds_inst|lcd_lvds|core|arch_inst|internal_pll.pll_inst|altera_lvds_core20_iopll. This refclk port on the PLL must be connected.
Info: Must be connected
Error: RST_N port on the PLL is not properly connected on instance i_M_MarlinHps|mm_video_mux|mm_video_mux|lcd_lvds_inst|lcd_lvds|core|arch_inst|internal_pll.pll_inst|altera_lvds_core20_iopll. The reset port on the PLL must be connected. If the PLL loses lock for any reason, you might need to manually reset the PLL in order to re-establish lock to the reference clock.
Try to upgrade your design and see if the IE has gone.
Richard Tan
sukesh
Hi Richard,
Thank you for this update. Will check on those errors.
I think 22.4 upgrade is helping it route the Internal errors on to the message window.
Sukesh
RichardTanSY_Altera
Since the IE has been resolved, I now transition this thread to community support.
Feel free to open a new thread if you have further questions.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
