17268 Discussions
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/vhdl/vhdlname_ela
When I was trying to synthesize following code:
process(CLK)
begin
if rising_edge(CLK) then
case find_1st_bit is
when first =>
if add2_finish = '1' then
cnt0 <= 0;
cnt2 <= 0;
find_1st_bit <= second;
else
find_1st_bit <= first;
end if;
when second =>
cnt0 <= cnt0 + 1;
TRAM(cnt0) <= RAM3(cnt0);
if cnt0 = 43 then
cnt0 <= 0;
cnt1 <= 15;
find_1st_bit <= third;
else
end if;
when third =>
if (TRAM(43)(15) = '0') then
cnt0 <= 43; cnt2 <= 43;
find_1st_bit <= fourth;
else
cnt1 <= 0;
end if;
when fourth =>
if cnt0 = 0 then
TRAM(cnt0) <= TRAM(cnt2)(15 downto 1) & '0';
cnt1 <= cnt1 - 1;
cnt0 <= 0; cnt2 <= 0;
else
cnt0 <= cnt0 - 1;
cnt2 <= cnt2 - 1;
TRAM(cnt0) <= TRAM(cnt2)(14 downto 0) & RAM3(cnt2-1)(cnt1);
end if;
when others => null;
end case;
end if;
end process;
I've got following message. Compilation in modelsim done well. Please help me to solve this problem.
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/vhdl/vhdlname_elab.cpp, Line: 1491dim + 1 < indices->Size()
Stack Trace:
0x38e90: vrfx_altera_assert + 0x20 (synth_vrfx)
0x1d305d: VhdlName::EvaluatePartial + 0x25d (synth_vrfx)
0x1d4fc1: VhdlIdRef::EvaluateName + 0x481 (synth_vrfx)
0x1d5680: VhdlIndexedName::EvaluateName + 0x440 (synth_vrfx)
0x1a0eaa: VhdlName::Evaluate + 0x1a (synth_vrfx)
0x1dd302: VhdlSignalAssignmentStatement::Execute + 0xd2 (synth_vrfx)
0x1d8c54: VhdlCaseStatementAlternative::ExecuteAlternative + 0x34 (synth_vrfx)
0x1e1495: VhdlCaseStatement::Execute + 0x535 (synth_vrfx)
0x1dc880: VhdlIfStatement::Execute + 0x3b0 (synth_vrfx)
0x1dd821: VhdlProcessStatement::Execute + 0x1d1 (synth_vrfx)
0x159b03: VhdlArchitectureBody::Elaborate + 0xd3 (synth_vrfx)
0x15d93b: VhdlEntityDecl::CoreElaborate + 0x42b (synth_vrfx)
0x15e00e: VhdlEntityDecl::Elaborate + 0x37e (synth_vrfx)
0x5169e: VRFX_VERIFIC_VHDL_ELABORATOR::elaborate + 0x1be (synth_vrfx)
0x4c3c6: VRFX_ELABORATOR::elaborate + 0xc6 (synth_vrfx)
0x9cb71: SGN_FN_LIB::elaborate + 0x131 (synth_sgn)
0x9f2fa: SGN_FN_LIB::start_vrf_flow + 0xa (synth_sgn)
0xa0627: SGN_FN_LIB::start + 0x597 (synth_sgn)
0x7dd79: SGN_EXTRACTOR::single_module_extraction + 0x149 (synth_sgn)
0x8264e: SGN_EXTRACTOR::recursive_extraction + 0x15e (synth_sgn)
0x8098b: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist + 0x2db (synth_sgn)
0x8268f: SGN_EXTRACTOR::recursive_extraction + 0x19f (synth_sgn)
0x85d4a: SGN_EXTRACTOR::extract + 0x16a (synth_sgn)
0xd118: sgn_qic_full + 0x138 (synth_sgn)
0x39cb: qsyn_execute_sgn + 0xeb (quartus_map)
0x19f2b: QSYN_FRAMEWORK::execute_core + 0x8b (quartus_map)
0x1c930: QSYN_FRAMEWORK::execute + 0xa0 (quartus_map)
0xf211: qexe_get_command_line + 0x1461 (comp_qexe)
0x116b7: qexe_process_cmdline_arguments + 0x387 (comp_qexe)
0x117a4: qexe_standard_main + 0x84 (comp_qexe)
0x17ede: qsyn_main + 0x5e (quartus_map)
0x1b91: msg_main_thread + 0x11 (CCL_MSG)
0x1be8: _thr_final_wrapper + 0x8 (ccl_thr)
0x1b05: msg_thread_wrapper + 0x85 (CCL_MSG)
0x218a: mem_thread_wrapper + 0x4a (ccl_mem)
0x28a03: msg_exe_main + 0x63 (CCL_MSG)
0x1938c: _main + 0x1c (quartus_map)
0x24ab4: __ftol2 + 0x1ce (quartus_map)
0x17076: RegisterWaitForInputIdle + 0x48 (kernel32)
End-trace
Quartus II Version 11.0 Build 157 04/27/2011 SJ Full Version
Without examine the code in detail I'd like to as if it would be possible for you to try to compile this design in a newer version of Quartus than 11.0? I would expect such an internal error to be fixed by now if it is indeed something in the code that generates it.
Looking into the code, my guess is that it is the index to RAM3 in the fourth case that might trick the mapper into believing that it could possibly go out of range. What happens if you try to compile with that line looking like this instead:
TRAM(cnt0) <= TRAM(cnt2)(14 downto 0) & RAM3(cnt2)(cnt1);
I understand that it will render a functional bug, I would just compile with this to see if that is what causing Quartus to error out.
Thank you very much for reply. I solved this problem by assigning RAM elements to another additional signal. Thanks a lot again.
