Internal Quartus Error
I am running Quartus II v13.1, and every so often (maybe 40% of the time) I get an internal error while compiling. If I restart the compilation it typically goes fine the second time through. I've posted the error message below, but I can't really make heads or tails of it. Can anyone help me understand what's going on and if it's a Quartus error or a system error on my machine?
Internal Error: Sub-system: HDB, File: /quartus/h/qtl_object_cache_sys.h, Line: 1042
m_locks == 0
Stack Trace:
0x7e280: HDB_ENUM_OPTION::get_value + 0x10b80
0x48257: HDB_ACTION_PT_INSTANCE::find_design_unit + 0x8b7
0x47f79: HDB_ACTION_PT_INSTANCE::find_design_unit + 0x5d9
0x4b8cb: HDB_CMP_ACTION_PT_INSTANCE::write_pdb + 0x1ab
0x45fa5: HDB_FILE_DEPENDENCIES::operator<< + 0x185
0x3681: PDB_BASE_SEGMENT::xfr + 0x431
0x45456: HDB_ACTION_PT_INSTANCE::operator<< + 0x256
0x4ea5b: HDB_CMP_ACTION_PT_INSTANCE::operator<< + 0x4b
0x529b: pdb_write_ptr + 0xfb
0x59e47: HDB_PARAMETER::get_option + 0x77
0x4a744: hdb_get_acf_section_type + 0x2e4
0x4b762: HDB_CMP_ACTION_PT_INSTANCE::write_pdb + 0x42
0x4802: QCU_ACF_SETTING::operator= + 0x2352
0x9d90: QCU_FRAMEWORK::write_named_databases + 0x1f0
0x1a89: Legacy_fitter_Init + 0xa19
0x21ac: Legacy_fitter_Init + 0x113c
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xc1ff: qexe_ipc_progress_bar_name + 0x12bf
0x11dd6: qexe_get_command_line + 0x1556
0x150d5: qexe_run_tcl_option + 0x585
0x1e03d: qcu_run_tcl_option + 0xb8d
0x156ed: qexe_process_cmdline_arguments + 0x54d
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0x1841: BaseThreadInitThunk + 0x19
0x57508: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Full Version
Thanks!
I don't think there's anything to 'make' of the error you've posted, other than to say Quartus isn't happy with something.
Given the version you're using is pretty stable all I can suggest is that you reinstall it. I've seen similar errors with earlier versions. However, I've used 64-bit 13.1 162 for a long time and don't recall ever seeing it fail in this way.
You don't say what it is you're compiling. Can it handle very simple projects? Or is it that it doesn't like a particular bit of IP you're using?
Cheers,
Alex
