Hello
I am using ModelSim-Altera as RTL simulator. And I am using NattoiveLink for Megafunction simulation. I have to launch simulation from menu of Tools > RTL simulation on Quartus II so far. Before simulation again, I have to Quit ModelSim every time also. If I can launch from ModelSim menu directly, it would be more convenient. Does anybody have a good idea? My environment is following Quartus II 64-bit Version 13.0 ModelSim ALTERA STARTER EDITION 10.0d Windows 7 Thank you Best RegardsLink Copied
I think you can since you can launch from your application. "Start menu" > Altera > ....
And in ModelSim, open the Modelsim project (Search for .prj in your project).- Mark as New
or simply run the script files in the \simulation\project directory. The script files are .do files
in the modelsim command window, type: do run_my_sim.do- Mark as New
Dear mmTsuchi and Tricky
Thank you for your advice. I have been able to use .DO file now. Thank you so much. And I'm sorry my late reply. Best Regards
