17252 Discussions
Is there a Bug about the Quartus II?
Hi!
I want to learn timing simulation with the Modelsim,but I meet a strange problem.I write a counter with the VHDL that can pass the RTL simulation but cann't pass the Gate level simulation.the Modelsim always notes that Errors occured in reading and resolving instances from compiled SDF file(s).
So I write the same function counter with the Verilog that can pass the RTL simulation and Gate level simulation,it's so amazing.
please help me?
VHDL Code:
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity FX is port(clk:in std_logic; reset:in std_logic; dataout:out std_logic_vector(3 downto 0) ); end FX; architecture behave of FX is signal mid:std_logic_vector(3 downto 0); begin process(clk) begin if(reset='1')then mid<=(others=>'0'); elsif(clk'event and clk='1')then mid<=mid+1; end if; end process; dataout<=mid; end behave;
Verilog Code:
module FX(clk,reset,data_out); input clk; input reset; output data_out; reg middle; assign data_out=middle; always@(posedge clk or posedge reset) begin if(reset==1'b1) begin middle<=4'b0; end else begin middle<=middle+1; end end endmodule
VHDL Testbench:
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY FX_vhd_tst IS END FX_vhd_tst; ARCHITECTURE FX_arch OF FX_vhd_tst IS -- constants -- signals SIGNAL clk : STD_LOGIC; SIGNAL dataout : STD_LOGIC_VECTOR(3 DOWNTO 0); SIGNAL reset : STD_LOGIC; COMPONENT FX PORT ( clk : IN STD_LOGIC; dataout : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); reset : IN STD_LOGIC ); END COMPONENT; BEGIN i1 : FX PORT MAP ( -- list connections between master ports and signals clk => clk, dataout => dataout, reset => reset ); init : PROCESS BEGIN clk<='0'; wait for 10 ns; clk<='1'; wait for 10 ns; END PROCESS init; always : PROCESS BEGIN reset<='0'; wait for 100 ns; reset<='1'; wait for 60 ns; reset<='0'; WAIT; END PROCESS always; END FX_arch;
Verilog Testbench:
`timescale 1 ns/ 1 ns module FX_vlg_tst(); // constants // general purpose registers reg eachvec; // test vector input registers reg clk; reg reset; // wires wire data_out; // assign statements (if any) FX i1 ( // port map - connection between master ports and signals/registers .clk(clk), .data_out(data_out), .reset(reset) ); initial begin clk=1'b0; forever# 10 clk=~clk; end always // optional sensitivity list // @(event1 or event2 or .... eventn) begin reset=0; @(negedge clk); reset=1;# 100; @(posedge clk); reset=0;# 10000; end endmodule
It's so unlucky,I installed the Quartus II 10.0 and Modelsim 6.5e today.but there is the same problem.
In your Verilog test bench the eachvec signal is declared but not used.
This creates an unknown signal.
Your process does not have a $stop; instruction at the end.
This keeps Modelsim simulating for very long time and can cause problems.
Without these small errors the simulation, both RTL and Gate Level proceeds without problems.
Further, I've never seen the use of negedge or posedge that you show in order to syncronize the test vectors with the clock.
However, it seems to work
Hope this helps.
