17255 Discussions
Issues with making a pipeline register in VHDL
I am currently having an issue with making a pipeline register in VHDL. A pipeline register is simply a register that connects two portions of a CPU pipeline together. It is easier to explain in code then on text in terms of its functions, so here is the code.
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity IF_to_ID_registers is port ( fetched_instruction : in std_logic_vector(31 downto 0); clear: in std_logic; writeregister : in std_logic; send_zeros_instead : in std_logic; clk : in std_logic; output_instruction : out std_logic_vector(31 downto 0) ); end IF_to_ID_registers; architecture Behavioral of IF_to_ID_registers is signal instruction_register : std_logic_vector(31 downto 0); -- The internal register begin process(fetched_instruction, writeregister, clk, send_zeros_instead) begin if ( clk = '0' AND writeregister = '1') then instruction_register <= fetched_instruction; -- Write the value into the register end if; if (rising_edge(clk)) then if (send_zeros_instead = '1') then output_instruction <= (others => '0'); -- Output zeros instead else output_instruction <= instruction_register; -- Output the register end if; end if; if (clear = '1') then instruction_register <= (others => '0'); -- Clear the register end if; end process; end Behavioral;
The issue I have with this code is that during compilation I get the following error messages.
Warning (10492): VHDL Process Statement warning at PipelineRegisters.vhd(42): signal "clear" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10631): VHDL Process Statement warning at PipelineRegisters.vhd(25): inferring latch(es) for signal or variable "instruction_register", which holds its previous value in one or more paths through the process Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled Warning (14025): LATCH primitive "IF_to_ID_registers:inst10|instruction_register" is permanently disabled
I am wondering what I did wrong. It seems like the issue stems from the instruction_register signal, but I cant tell what the issue is.
It seems like I need to implement the register as an edge based write and a level based read. Is there any way how to do that?
the output of a register is avaible to whoever wants to read it at any time. No levels required. but be aware of the implications of asynchronous reads of registers (ie. metastability - reading during a change of value).
