17263 Discussions
Kernel Vectorization query
I am trying to incorporate the kernel vectorization optimization
I get the following compiler warning
Compiler Warning: Kernel is vectorized but there exist loads/stores that cannot be vectorized. This may reduce performance.
The following are the details:
Global thread dimension: 240 x 540
Local Work grp dimension 240 x 1
Input dimension 1920 x 1080
I used following attributes
_attribute__((num_simd_work_items(4)))
__attribute__((reqd_work_group_size(240,1,1)))
input loading code snippet :
for(UInt32 i = 0 ; i < 8; i++)
tempin[lidx + i * 240] = input[lidx + i * 240];
where
lidx: local_work_id in x direction with max val as 239 (since Local wrg grp dim 240 x 1)
tempin is a local memory buffer which is used for per workgrp computation
Can anyone suggest way to avoid this warning.............?
Let me know if I have to furnish any more details ......
Neelakandan
reqd_work_group_size might be set to be the power of 2, 240 is not normal.
Hi
Even after specifying the required work group size as a power of 2 (Instead of 240 I specified it as 256), I get the same warning message...
Can there be any other reason ?
It is about "lidx + i * 240", the AOC cannot analyze them effectively, which leads to suboptimal performance.
You may try the "#prama unroll" before the for loop.
