17252 Discussions
[Kernel vectorization] Loads/Stores cannot be vectorized
Hi guys!
The compiler says this on the above code:
Compiler Warning: Vectorized kernel contains loads/stores that cannot be vectorized. This might reduce performance.
What loads/stores are causing this?
--- Quote Start ---
__attribute__((num_simd_work_items(16)))
__attribute__((reqd_work_group_size(32,1,1)))
__kernel void int_loop(__global const short * restrict a,
__constant const bool * restrict b,
__global int * restrict group_counters,
__local int * restrict local_counter,
const int base, const int base2)
__private uint local_id = get_local_id(0);
__private uint group_size = get_local_size(0);
__private uint global_id = get_global_id(0);
__private int g1 = a[base + global_id];
__private int comparison;
__private int wi_counter;
comparison = (g1 == a[base2 + global_id]);
wi_counter = comparison & b[global_id] & (g1 != 0);
local_counter[local_id] = wi_counter;
for(uint stride = group_size >> 1; stride > 0; stride = stride >> 1)
barrier(CLK_LOCAL_MEM_FENCE);
if(local_id < stride)
local_counter[local_id] += local_counter[local_id + stride];
if(local_id == 0)
group_counters[get_group_id(0)] = local_counter[0];
--- Quote End ---
The likely case is the following part:
if(local_id == 0) group_counters = local_counter;
SIMD vectorizes operations at work-item level, and coalesces accesses that are consecutive at this level. For this particular access, since the write is done only by one work-item per work-group, it cannot be vectorized/coalesced.
--- Quote Start ---
--- Quote End ---
Always right mate :)
Thanks HRZ
