Latch Inferred Help
Hi everyone.
I have a code in Verilog, wich must be combinational, but I can't figure out how to make it without creating a latch.
The logic is correct, and simulates fine, but I'd like to remove the latch.
module locker ( input wire INPUT, output reg lock ); localparam high_low_threshold = 16'b00000001_10011001; localparam low_high_threshold = 16'b00000100_00000000; always @ ( * ) begin lock = 1'b0; if (INPUT >= low_high_threshold) lock = 1'b1; else if (INPUT < high_low_threshold) lock = 1'b0; end endmodule
Thank You!!
i'm not really sure in verilog, but the first
lock = 1'b0
seems wrong to me.
if you walk through the code, you assign the output lock twice. So your logic don't exactly know what to do.
I think you have to move this into the "else" path of the second if. By this way this default-assignment will only be done, if the other two if-cases don't occure.
try using non-blocking assignments with <= assignment, rather than blocking.
The shown code doesn't generate a latch, neither with blocking nor nonblocking assignments.
--- Quote Start ---
seems wrong to me.
--- Quote End ---
The default assignment lock = 1'b0 is required to avoid a latch.
I'm more into VHDL. If you assign two different values in one walk through there, you will surely get unexpected behaviour.
The code shows the variable will take one value - 1 or 0. The top value is the default value if the other two situations do not occur.
--- Quote Start ---
--- Quote End ---
No unexpected behaviour, neither in Verilog nor VHDL.
Multiple assignments in sequential code (Verilog always block or VHDL process) are pretty legal. In case of VHDL signals and non-blocking Verilog assigments, only the last assignment will take effect. In case of VHDL variables or Verilog blocking assignments, previous assignments matter, if they are read during the sequential code. In any case, the final assignment will be kept until next schedule of the sequential code.
Multiple assignments in concurrent code, including assignments to the same variable/signal in different sequential blocks cause a "multiple driver" error in hardware synthesis.
@rafael_kl
Why do you think the latch is created in the first place.
