Logic Element
I have 1 design which use total of 734 logic element. When i want to optimize the design by doing chaining(remove one 32 bit register), the logic element used is 733. since 1 FF consists of 2 NAND or 2 NOR gate, 32 bit register will have 64 logic elements. The logic element used is 670 instead of 733. May i know the reason why?
FYI, i use cyclone II.
Well the term "logic element" is a bit fuzzy and truly is defined by the architecture. But specifically according to page 2-2 of the Cyclone II datasheet:
http://www.altera.com/literature/hb/cyc2/cyc2_cii51002.pdf
a LE consists of:
--- Quote Start ---
- A four-input look-up table (LUT), which is a function generator that
can implement any function of four variables
- A programmable register
- A carry chain connection
- A register chain connection
- The ability to drive all types of interconnects: local, row, column,
register chain, and direct link interconnects
- Support for register packing
- Support for register feedback
--- Quote End ---
Jake
