17251 Discussions
MAX V - Reliability in design issues
I am having trouble to develop a consistent/reliable program on a CPLD MAXV reference 5M2210ZF256C5. I am using the free version of Quartus v13.1.3 64Bits. The input clock of the system is 100MHz.
I have used different programming inputs to program different blocks into my CPLD: Verilog HDL, VHDL and schematic. As the amount of blocks started to increase, I noticed some strange behaving of my CPLD. Time to time, I change some parameter of the design into some block and I have another block not working on the same way or at all. For example, I am using a block to store the serial number of the CPLD program which I increment for every revision and just changing the serial number has some impact somewhere else on the design. I tried to work on the different blocks and optimize their speed as much as possible but I still find the same type of issues. Do you think that such issues could be solved out by buying the licensed version of Quartus and use the “LogicLock™ incremental design capability” of Quartus?
I have attached a vhdl code that I would like you to check. As described above, this block works properly time to time depending of the serial number affected to another block. I just cannot get that! The serial number is defined using an LPM_CONSTANT plugin and depending of the value of the constant, the vhdl code attached works on a different way even if the serial number LPM_CONSTANT plugin is not connected at all to the block below!
Your help is greatly appreciated.
Fabe
You have an combinationally generated clock, which is likely to fail due to glitches even if there are no domain crossing signals between i_clock and SAWTOOTH_CLOCK domain.
SAWTOOTH_CLOCK <= '1' when ( cont_reg < 3 ) else '0';
At this point I stopped checking for possible additional design issues. I guess, the design never passed timing analysis?
I ran a timing analysis using TimeQuest and generated a SDC file using TimeQuest analyser wizard. It seems that many time constraints are not fulfilled. Moreover, when I open my wizard generated SDC file, I read comments like:
“# Automatically calculate clock uncertainty to jitter and other effects.
# derive_clock_uncertainty
# Not supported for family MAX V”
The problem here seems to be the generation of the 12.5 MHz clock from a 100 MHz input clock. I would have done this using a PLL on a FPGA but I cannot do that on a CPLD. Is there a way to properly create a generated clock with VHDL or should I think of another approach to build this block?
Thank you in advance for your comments.
Fabe
SDC file:
# Clock constraints
create_clock -name "clk" -period 10.000ns [get_ports {clk}]
create_generated_clock -name clk_sawtooth -source [get_ports {clk}] -divide_by 8 [get_registers {Sawtoothx:inst|cont_reg[2]}]
# Automatically constrain PLL and other generated clocks
derive_pll_clocks -create_base_clocks
# tsu/th constraints
set_input_delay -clock "clk" -max 0.5ns [get_ports {reset}]
set_input_delay -clock "clk" -min 0.125ns [get_ports {reset}]
# tco constraints
set_output_delay -clock "clk" -max 0.25ns [get_ports {CS}]
set_output_delay -clock "clk" -max 0.25ns [get_ports {DOUT}]
set_output_delay -clock "clk" -max 0.25ns [get_ports {SCLK}]
# tpd constraints
set_max_delay 0.125ns -from [get_ports {reset}] -to [get_ports {CS}]
set_max_delay 0.125ns -from [get_ports {reset}] -to [get_ports {DOUT}]
set_max_delay 0.125ns -from [get_ports {reset}] -to [get_ports {SCLK}]
Generate an 'enable' signal that is active every 8th clock and use it to qualify all the logic that needs to run at 12.5MHz
Ok, thanks FvM and dsl for your suggestions :)
Created a separate COMPONENT triggered by the 100 MHz clock to create my 12_5MHz clock and instanciated in "Sawtoothx" entity. It seems to work better. I will try an "enable" signal if I see some other issues.
--- Quote Start ---
--- Quote End ---
A component doesn't change anything. At least SAWTOOTH_CLOCK must be registered. (It might be that the combinational expression for SAWTOOTH_CLOCK maps to a single FF output. In this case, it would be glitch-free without being explicitely registered)
You have several domain crossing signals with i_clock as launching and SAWTOOTH_CLOCK as latching clock which likely causes timing violations, e.g. current_state.
I guess there's no substantial reason for this clock topology. Using SAWTOOTH_CLOCK respectively a new signal that is active for one i_clock cycle as a clock enable is however the straightforward way to get rid of domain crossing problems.
Or don't register any internal signals under i_clock control.
Taking into account your suggestions with clock enable signal, I made some modifications (Attachment). Would the functioning be more robust now and would the synthesiser would synthetize this properly without glitches?
I didn't the design in depth but the clocking looks good now.
Ok, thanks for your comment FvM.
