17263 Discussions
Math calculations in VHDL
Hi all,
I need a little help with my design, there are a few issues that I'm trying to resolve.
My design flow is as following: A signal is sampled by a 16bit A2D, multiplied by 2 another 16bit signals (which results in 2 32bit signals). After a few manipulations I need to implement a formula that uses those 2 signals with division, multiplication and a few other functions that are calculated using LUTs. The LUTs are designed for a signal normalized to the range of 0 - pi/2. Note that after the formula the signals will be converted to 32bit floating-point signals.
The formula requires some fractional calculations so I'm trying to use the fixed point package by David Bishop but I'm facing a few issues:
1. How am I supposed to convert the 32bit signals (integer) to 32 fixed point numbers?
2. I'm trying to divide the 2 32bit signals - what is the best way to do this? I tried the lpm_divide megafunction but I get a quotient and a remain while I need the whole number (i.e. 5.65 and not only 5).
3. How exactly am I supposed to use the fixed-point package? I have the following libraries, is that enough?
Library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.fixed_float_types.all;
use ieee.fixed_pkg.all;
Thanks in advance, help will be very appreciated.
--- Quote Start ---
Got it, thank you.
--- Quote End ---
pls publish the code which u hv got
