Maximum width of FIFO
The maximum width of a FIFO in the IP catalog GUI wizard is limited to 256 bits.
I need a wider FIFO and want to avoid cascading FIFOs.
Will it work to manually change the generated HDL instantiation file to the width I desire (for example 1024 bits) ?
Did you try it? what were the results?
Why not use two parrallel fifos?
--- Quote Start ---
--- Quote End ---
No it isn't. IP user guides say
--- Quote Start ---
Note that you can manually enter a number that is not in the drop-down list.
--- Quote End ---
