17255 Discussions
Measuring Frequency help
I need to measuring a signal frequency
i have a reference frequency of 100 MHz
i used the following code bu it didn't work properly
it counter right at the first but after that it got wrong:
process(n_reset,clk_ref100,clk)
begin
if n_reset='0' then
s_clk_ref100_counter<=(others=>'0');
elsif rising_edge(clk_ref100) then
if s_clk_ref100_counter>=10000 then
s_freq<=s_sys_clk_counter;
else
s_clk_ref100_counter<=s_clk_ref100_counter+1;
end if;
end if;
if n_reset='0' then
s_sys_clk_counter<= (others=>'0');
elsif rising_edge(clk) then
if ((s_freq<=s_sys_clk_counter-5) and (s_sys_clk_counter/=x"000"))
then
else
s_sys_clk_counter<=s_sys_clk_counter+1;
end if;
end if;
end process;
Please advice me.
how fast is clk? the fact you are samplining a 100MHz counter in another clock domain and vice versa is probably your problem. You will need to transfer the counters across the clock domains safely, either with a double register or a dual clock fifo.
I tiried with triple register and it worked
thanks
