Hi
Can Altera quartus II generate verilog code from megafunction? thxLink Copied
Megafunctions can generate a Verilog module as primary entity. It's ususally importing additional libraries that may be written in VHDL, Verilog, AHDL or possibly encrypted HDL.
Verilog libaries for functional simulation are additionally provided,- Mark as New
Sorry, I still not very clean about that, I only can find a verilog file which can change the parameter, but cannot see overall verilog code. How to see the whole verilog code?
you are not meant to see the internal verilog code.
Which particular MegaFunction are you talking about?
For example, I open block diagram and insert a multiplier from megafunction, I only can found a top level verilog file, can I see the whole verilog code for the multiplier??
The Verilog MegaFuction is instantiating lpm_mult, also multipliers inferred form HDL code do. As most low level libraries, it's coded in AHDL. See lpm_mult.tdf and additional code in multcore.tdf which can be found in quartus\libraries\megafunctions.
There's no Verilog multiplier code. As already mentioned in post# 2, the internal library code (as far written in readable HDL) uses different languages, in this case AHDL.
