I downloaded the Quartus 10.1 version and I can't use the Megawizard. In real, I can't see the whole windown when I startup any function. I can't move the windown, I can't click in "finish" bottom because it doesn't appear...I can only close it by ALT F4 command... I use Windowns XP... Somobody can help me ?链接已复制
2 回复数
If I remember right, the problem exists since several Quartus versions with some large MegaWizard windows, if your screen height is 1024 (XGA) or below. Seems to be a matter of bad IDE programming.
