17268 Discussions
Migrate to Max V problem.
Hi. I had one design which used EPM3064ATC44-10. Now I need to convert to 5M80ZE64C5.
I use AHDL and Quartus II 64 bit 10.1 Web (service pack 1). I got this error
Error: Fitter requires 9 LABs to implement the project, but the device contains only 8 LABs
I still have some LE left.
Total logic elements 69 / 80 ( 86 % )
How can I make the fit to avoid select the next device which is 5M160? Many thanks in advance.
Could it be a bug in the software? As I understand that 5M80ZE64C5 should have more than 8 LABs.
the MAXV architecture manual says each LAB contains 10 LE. 80 LE => 8 LABs sounds right
