17255 Discussions
Migrating from MegaWizard to IP catalog issues
I have installed QII14.1, and found that it seems remove MegaWizard and insert IP catalog. Now, i used QII14.1 open my previous project, however, i don't know how to edit the IP (for example, PLL) implemented in old version by using MegaWizard.
Can anybody help me about this?!
try using file=>open and open it through that
**to clarify a bit more, when you created the ip with the megafunction it would have made a vhdl/verilog file which is what you can open which should open the dialog again to edit
Starting from QII 14.0, the IP Editor has replaced the previous megawizard. So, you could not use megawizard to edit your file in QII 14.1. As a workaround, you may try archive your older QII version project ie 13.1 and then use QII 14.1 to un-qar the project QAR. By default, the QII 14.1 will perform auto IP upgrade and then you could use IP Editor to edit your IP instances.
